Halogen bulbs vs. HID
Old Dec 14, 2011 | 02:40 PM
dannygjatt's Avatar
Default Halogen bulbs vs. HID
Thinking about upgrading my halogens to HID. Would there be more battery drainage from HIDs? I was looking at 4000 or 6000 kelvin. Also, the installer said that if I upgraded to the HID, I would not be able to use the "auto" headlamp feature. Something with the voltage would drop too much and they could flicker. Has anybody upgraded or have any helpful suggestions?
Old Dec 14, 2011 | 06:40 PM
jagular's Avatar
No effect on battery as the current will come from the alternator. I think HID also draw less current than halogens.
I cannot see how the type of bulb could affect the Auto headlight function. The activation is from an optical sensor and current draw or voltage at the lights is irrelevant. Don't know this for sure but the installer should explain to you how this can be.
Old Dec 28, 2011 | 01:02 AM
upsdude's Avatar
just put in a drop in kit on my '03 xtype, and the light output doesn't seem bright enough. i'm using 5k 35w kit. just replaced the battery could it be a sign of an alternator on it's way out?
Old Dec 28, 2011 | 06:43 AM
Rique's Avatar
The difference should be like night and day for a HID vs Halogens. HID are a go no go system. If you have the right voltage the unit turns on if not they don't work. I suggest you take a look at ddm tuning. Cheap kits that work great.
jagent
Jun 5, 2022 02:18 PM
goingjag
Sep 30, 2015 09:27 PM
redrover41
23
Sep 25, 2015 01:33 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
