Heater blowing cold air
Old Feb 9, 2023 | 08:51 AM
clintdeadwood's Avatar
Default Heater blowing cold air
Hi all,
I have a Jag XF 2012 2.2D and my heater has recently stopped blowing hot air, the dashboard vents were having an intermittent problem prior to this whereby sometimes they would rotate as they should when turning on ignition but sometimes they wouldn't. It's cold here in the uk at the moment and i can't clear my screen due to only having cold air, could anybody tell me where to start with this issue.
Thanks in advance
Old Feb 9, 2023 | 12:13 PM
John Williams's Avatar
Diesel engines take a long time to warm up so your car is fitted with an electric pre-heater. If the heater has a fault it can cause a spike in the Lin, these causes the heater to do strange things, including the vents doing strange things. You can disconnect the pre-heater easily & the climate will return to normal.
Old Feb 9, 2023 | 12:15 PM
There's a video on youtube by Sofa Warrior that shows how to disconnect.
I tried to paste it in here but wouldn't work for some reason!
Old Feb 9, 2023 | 01:36 PM
Thanks John i will check this out
Old Feb 9, 2023 | 09:27 PM
kansanbrit's Avatar
Probably air in the system, check coolant topped up and use bleed screw in heater feed pipe to extract air.
Old Feb 10, 2023 | 04:27 AM
Default Fixed!!!
Pleased to say that disconnecting the pre heater has fixed the issue, was a little bit fiddly but anybody who has a similar issue shouldn't be intimidated by it and have a go yourself. Total time taken was about 10 minutes and now the wife has promised to do disgusting things to me later as payment so all's well that ends well!!!!
Old Feb 10, 2023 | 05:19 AM
Bigv's Avatar
Ya beauty!!
please keep us updated!
Stivan
Jun 22, 2021 01:34 AM
JagJoe80
Mar 3, 2019 09:34 PM
creuse101
Apr 26, 2014 10:44 AM
yellowapple
Mar 18, 2014 07:10 AM
starscream
Mar 1, 2012 07:08 AM
