How to Dyno Newer Jaguars
Old Sep 21, 2012 | 05:41 PM
BigCat09's Avatar
Question How to Dyno Newer Jaguars
I would like to know how you put these new Jaguars into Dyno Mode to run them on the Dyno?
I have tried 2 different Dyno shops wit hmy XFR and have had some issues dyno this car properly. I uncliped and removed the coolant bottle to get access to the coil pack/inj wires for a tach signal/reading. I turned DSC all the way off and put gear in S mode and attempted to use 4th gear as my pull. But soon as I floor it the car will kick down to 3rd gear. I think if I do not floor the gas all the way but rather hit it down to the micro switch for the kick down gear button it would hold 4th gear but I am not sure. What rpm/speed should I start with in 4th gear for dyno runs?
And I know there must be some Hidden Menu, Dyno Mode, Secret Menu, Engineering Menu somewhere in these cars as Dyno Mode is needed all around the globe. So how can I keep the cluster from giving tons of faults when dyno , get a good tach signal, and hold 4th gear please?
Old Sep 21, 2012 | 07:37 PM
doc's Avatar
doc
With My 95 xjr we had to keep it in 3rd gear and gently build the throttle up
Old Sep 22, 2012 | 12:33 AM
avos's Avatar
You can only floor it if you have past the shift down rpm, there is no way to keep the box into a gear below that with full throttle. Not sure where the point is for your car, but on mine I usually go close to 4000 rpm and then floor it (in 4th).
JarodL
Mar 7, 2024 01:39 AM
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
David Thompson
Sep 3, 2015 07:48 PM
