How much engine oil is too much?
Old Nov 21, 2017 | 09:52 PM
dpresent's Avatar
Default How much engine oil is too much?
The owner's manual calls for 7.25L engine oil. I checked today and the reading (at operating temperature) was 7.5L. Can the extra .25L damage the engine or cause any other negative effects?
Old Nov 21, 2017 | 10:02 PM
OzXFR's Avatar
An extra 250 ml won't cause any problems, assuming the reading is accurate.
You would need to overfill by 2 litres or more to cause real problems.
Old Nov 22, 2017 | 12:31 AM
Swimref's Avatar
While this may be true for some engines, it is by no means true for all. In the case of the Jaguar 5 liter direct injected motor, the factory manual states in no uncertain terms that half a liter overfill means park it immediately for a partial pumpout or tow to the dealer. I have owned two cars in my past that blew head gaskets due to minor oil overfilling, it can be very damaging if this happens.
