Intercooler pump
Old Jun 24, 2021 | 08:45 AM
bfarrell's Avatar
Default Intercooler pump
Will a faulty intercooler pump always throw a code. Im trying to track down SC boost fall off at WOT. Changed the belt which helped a bit due to some slippage. Im getting no codes other than p402 (catalytic converter) however the supercharger pulls well during part throttle then quickly flattens out with WOT. I have a Velocity tune and larger lower pulley good for 450HP. Im not seeing anywhere near that… trying to sort it all out.
Old Jul 6, 2021 | 08:21 AM
kansanbrit's Avatar
I doubt it will ever throw a code. Maybe sticking a thermocouple on the supercharger lid would give you an idea of air temp going into the engine?
Old Jul 6, 2021 | 09:37 AM
User 42324's Avatar
You should be able to monitor the IAT2 temps & the timing through live data. You'll be able to compare temps on steady part-throttle against WOT. At the same time you'll also be able to see if it's pulling timing.
Old Jul 10, 2021 | 12:53 AM
AlexJag's Avatar
Sponsor
Whats your car?
Because with our tune boost does not fall off. We just set a record for fastest 5.0sc car btw
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Jul 10, 2021 | 09:38 AM
bfarrell's Avatar
Default Tune
Originally Posted by AlexJag
Whats your car?
2013 XF sport AWD 3.0 SC
Velocity AP tune
Outrun
Nov 6, 2020 12:13 PM
loveatfirstsight
Apr 21, 2014 01:37 AM
WaterDragon
Apr 19, 2014 10:17 AM
Ziggy
May 21, 2013 09:37 PM
Candy's Kitty
Sep 19, 2012 02:41 PM
