Jaguar XF 2.7d Hand glove Box fuse
When i change the fuse for the Hand glove box, i want to put the new fuse and befor i can put it its again burned the fuse, what that be. i have try it 10 times when i put a 25A fuse is working but i am affraid because normal is a 15a fuse.
Thanks for the help.
Kind regards
Kurt Iselii
Kind regards
Kurt Iselii
Indeed, never fit higher rated fuses, they're fitted to prevent the wiring overheating ( and caching fire ), and also to prevent the circuit traces being burnt off the board in the junction box they're fitted too. Either of those will be a very expensive mistake, and you also have to consider the risk of fire while the car is at high speed so the occupants can't immediately get out.
