Jaguar XF (X250) Estate Reversing Lights Always On
Old Oct 21, 2022 | 06:40 AM
beast900's Avatar
Default Jaguar XF (X250) Estate Reversing Lights Always On
Hi All,
I am wondering if someone can help with this weird problem I have developed with my 2014 (X250) Jaguar XF 2.2 (TDi4 163) Diesel Estate.
About two weeks ago I noticed the reversing lights are always on. It doesn’t seem to matter if the automatic gear box is in drive, park, reverse etc,
Even when the car is not running and locked they are still lit up.
The only way I have managed to get them to go out is to actually disconnect the battery.
I have been trying to work my way through the wiring by looking at various diagrams I have found online but no joy so far.
I am thinking it could be sometihng to do with the computer or CAN bus but I will be honest I haven’t a clue.
Has anyone had this issue before? Or does anyone know of anything I could try?
I spoke to Jaguar and they want £175 just to run some diagnostics so I want to avoid that if possible and see if I can sort it myself.
Any help or advise would be greatly appreciated.
Thanks in Advance
Tony
Old Oct 22, 2022 | 04:27 AM
Nigwel1058's Avatar
Originally Posted by beast900
Hi All,
Thanks in Advance
Tony
It could be the reverse light switch.
haven’t a clue where that is though!!
gearbox area ish!!
Old Oct 22, 2022 | 02:42 PM
sportbrake_phil's Avatar
Hi All,
Thanks in Advance
Tony
The reversion lights are controlled by the RSJB/BCMB/RJB it's located behind the little pull out panel on the right side as you look in with the tailgate open. First check for any signs of water ingress into that junction box ( any signs of water, or green "copper" deposits on any of the connectors ), it's been known for the bolts that hold the "rams" that keep the tailgate open to leak, and water to run down inside the d pillar, and drip onto the RSJB.
The green/blue wire on the second top connector on the left of the RSJB powers the reversing lamps, I'd suggest first checking the voltage there, ( presumably 12v if the lamps are on ), then disconnecting that wire. If the lights are still on with the wire disconnected it seems the logical explanation will be a short in the wiring ( to another live wire ) somewhere between there and the the lamps.
Old Oct 24, 2022 | 11:03 AM
beast900's Avatar
gearbox area ish!!
Thanks Nigwel1058, I will do some digging! :-)
Old Oct 24, 2022 | 11:04 AM
beast900's Avatar
Thanks Sportbrake_phil,
thats great, I currently looking in that area, and I suspect the same as you (at the moment anyway). Let me have a good check and trace,
Will let you know how I get on
Tony
Dayzel108
Dec 15, 2023 04:41 PM
Salvenzo
XF (X260)
Jan 6, 2023 04:29 PM
lespres
Jul 5, 2022 06:05 PM
geniusgillius
May 22, 2022 05:06 PM
scottyb01
Mar 14, 2012 10:26 AM
