"Keyless start back up. Smart key error" After Battery Replacement
Old Jan 4, 2022 | 06:34 AM
mdk2000's Avatar
Default "Keyless start back up. Smart key error" After Battery Replacement
Hi guys, I've just had the main battery replaced on my 2013 facelift XF 2.2D, and the smart key won't let the car start anymore. The error is exactly as in the title.
I'm holding the key against the bump 2-3 inches below the fog light switch. Regardless of key orientation, the first time I press start, I get "Unable to find smart key. Refer to handbook", then I get "Reposition smart key and press start button", and then eventually "Keyless start back up. Smart key error".
I'm at my wits end as to what to do next, other than to have it hauled off to a dealer - which I want to avoid because I'm not in my home country right now and that hassle will eat a ton of time and money.
Any help appreciated!
Old Jan 4, 2022 | 04:07 PM
MoJo88's Avatar
Common and know fault on the X250 2012-2015. Search the forum for various posts regarding it and it's fix.
Quick heads up - BCM corruption due to battery disconnect.
Old Jan 6, 2022 | 02:45 AM
litteredwithfaults's Avatar
https://www.jaguarforums.com/forum/x...onnect-192543/
Old Jul 26, 2022 | 09:47 AM
dhemphill's Avatar
Hi mdk200 - i have exactly the same issue. Did you find a solution?
Old Jul 26, 2022 | 01:24 PM
John Williams's Avatar
You need to run "immobilisation" in SDD
Old Jul 26, 2022 | 05:37 PM
dhemphill's Avatar
Thanks. I've ordered a cable and just need to locate the software. How easy is it to run the procedure, do I need to connect to a back-up battery or power source?
Old Jul 29, 2022 | 10:38 AM
dhemphill's Avatar
Can you run that function with ignition off? I can't turn on the ignition...
Old Nov 12, 2022 | 07:29 AM
Don.Tomm's Avatar
Default Thanks
Hi mate, thanks for your availablility, so, how i can with jlr sdd v160? Seems really more difficult to be as v154. But i can't find v154 online .
Old Nov 12, 2022 | 07:30 AM
Don.Tomm's Avatar
​​​​​Hi mate, not find with v160. How i can ?
Old Nov 12, 2022 | 04:17 PM
This was copied from a FB page......Jaguar XF remote lock/key not recognised issues.
I've been getting many requests from the group via word of mouth and I've done quite a few.
Issue one most common:
Car won't lock after battery disconnect. This is solved via immobilisation in SDD.
Issue two less common:
Key not recognised at all hence no ignition, immobilisation not possible.
This is done via cluster reprogram as it will bypass the key sequence, turns ignition itself and do the immobilisation at the end.
This will also update cluster to latest software, bonus.
Please don't throw suitcases of money on KVM module/keys and what not, I've never seen a faulty KVM module.
I charge 50 for it if you come with the car in Keighley or Shipley, West Yorksire. United Kingdom that is.
I can also do any sort of programming, retrofits, CCF editing.
I have the latest SDD and Pathfinder and I am the one selling the complete units on eBay over 110 sold.
Also do not throw money in any tools no matter what the sellers say, only SDD can do it no Autel etc.
Old Nov 12, 2022 | 05:28 PM
Don.Tomm's Avatar
Default Thanks
​​​​​​Thank you mate. I'm obliged to program new key modules as new key programmation, dashboard modules and gear modules. After i had to reinstall new brake modules and new abs . Now is totally perfect but really hard job and more than 3 hours of job. I have mongoose sdd jlr v160.
Old Nov 26, 2022 | 05:24 PM
no1's Avatar
no1
could u add the link to this fb page I would like to contact him or find out what his complete units on ebay are called to buy one
Old Nov 29, 2022 | 04:26 AM
no1's Avatar
no1
where did uget your mongoose cable that is compatible with jaguar? Ive been on drew techs website and i cant find it anywhere on there?
Old May 9, 2023 | 07:32 AM
lambbhuna's Avatar
hi do you have a link for ebay
Old Sep 5, 2023 | 04:48 AM
JohnBreen's Avatar
hello there,
did you manage to get the issue resolved as i have the exact same issue?
kind regards
john
Old Sep 5, 2023 | 11:34 AM
MoJo88's Avatar
Originally Posted by JohnBreen
hello there,
kind regards
john
Let me know if you require help with this. I can be available to come to Royston to fix this for you.
Send me a PM if required
Old Sep 7, 2023 | 05:30 AM
JohnBreen's Avatar
hi there and thanks for getting back to me.
I am in Royston Hertfordshire if that makes a difference, I have the sdd software and teamviewer if you could help me remotely and I would be more than happy to pay for your time.
kind regards
john
Old Sep 10, 2023 | 02:22 AM
danciosubaru's Avatar
Default Smart key not found
are you able to come and solve this problem at home ?
Old Sep 10, 2023 | 02:24 AM
MoJo88's Avatar
kind regards
john
As mentioned - send me a PM.
Old Sep 10, 2023 | 02:25 AM
question for John Williams
