Largest Rim size??? Without rub 2013 XF 3.0L awd w
Old Mar 29, 2017 | 08:19 PM
Sbuz1547's Avatar
Default Largest Rim size??? Without rub 2013 XF 3.0L awd w
What's the largest rim n tire size I can go comfortably with a 13 xf awd.. I don't want to rub but I don't want rubber bands for tires
Old Mar 29, 2017 | 10:42 PM
BlckCat's Avatar
The largest OEM size is 20" but I've seen guys do 22". I think even my stock 20s are too big. I'm considering going down to 18s the next time I need tires.
Old Mar 30, 2017 | 06:21 PM
pdupler's Avatar
Subscribed out of curiosity. I would need all the sidewall I could get, but apparently 17s won't fit except on the 4cyl cars. Don't want a 4cyl, so its probably just swapping out the Caravellas for base 18s and bumping the aspect ratio as much as it can take.
Old Mar 30, 2017 | 08:01 PM
Shadow993's Avatar
20" is perfect, but needs taller tires
Old Mar 30, 2017 | 08:49 PM
BlckCat's Avatar
This is a great website for calculating equivalent rim and tire sizes:
http://www.rimsntires.com/specspro.jsp
Sbuz1547
Apr 6, 2017 03:51 AM
