Leaking coolant - any ideas???
Old Dec 19, 2021 | 09:02 AM
memento84's Avatar
Default Leaking coolant - any ideas???
Hi All,
replaced pump, gaskets, both o-rings + plastic tube connecting to pump and it is still noticeably leaking (10-20uL/sec???).
Coolant accumulates in the little "drawer" behind the pump and "overflows" and leaks from the front.
What else can be causing a leak with a "front of the engine" symptom?????
2013 XF 3.0 AWD
Here is the pic where the coolant accumulates with an arrow showing the direction of the flow (have an endoscopic camera to inspect).
Any ideas are much appreciated!
Old Dec 19, 2021 | 09:25 PM
memento84's Avatar
Is there any chance that the plastic connector, oil <-> water pump is still the culprit? Multiple threads here at forums mention "fitting" it a problem (some ppl reported multiple attempts to put it together?). Is there any "procedure" to put it together correctly? Have someone tried putting double o-rings on both ends?????
Old Dec 19, 2021 | 09:46 PM
davetibbs's Avatar
Yup, I'm with memento84. For the water to pool in that area it's either going to be the O-Ring(s) on the plastic pipe on the back of the pump, or maybe the o-rings in the base of the Y pipe, but honestly that joint is high enough you'd see it weeping, so we have to assume it's from the pipe on the rear of the pump.
Old Dec 19, 2021 | 10:21 PM
memento84's Avatar
It started last month - I had ample time to inspect the area + now endoscopic camera. The plastic "Y" does not seem to weep anything (that would be visible, one way or another). I am still considering the "lower" section of the "Y" ? But to be honest, it looks like the plastic connector. There is a chance that I got the metal pipe misaligned or maybe even pushed back (the one coming out of oil cooler) in one of the attempts.
Should the distance between oil pipe collar and inside of the pump be as such that both o-rings in and out on the connector get a "tension" when the pump is screwed in, or they can be relatively "soft"?
just my thought
Old Dec 24, 2021 | 07:32 AM
Rummy636's Avatar
I would check the "Y" pipe. If its the pipe with the seam, its most likely the culprit. The updated molded hose dont normally have issues.
greatXK8
Jun 27, 2021 08:10 AM
ArtyH
Nov 20, 2013 05:09 PM
Skid Mark
Dec 29, 2011 04:17 PM
sivkov-y
Feb 24, 2011 02:33 AM
hankycbr
Oct 9, 2007 04:21 AM
