Looking at a 2010 XF
Old Nov 14, 2016 | 06:09 AM
Fairlane500's Avatar
Default Looking at a 2010 XF
I am seriously looking at a 2010 XF Premium in Liquid Silver. It has just over 36K miles. Is there anything I should be specifically looking for? Any words of wisdom from current owners?
JonF
Old Nov 14, 2016 | 02:01 PM
BritCars's Avatar
This one has been very well covered in many similar threads so worth searching around the Forum
Overall it's a terrific car and think you'll be delighted with it. A few thoughts on what to look for
- the usual - full service history, ideally with dealer or experienced jag mechanic
- check types, brakes and rotors. It can eat them all and they are not cheap to replace
- check wheels carefully / the larger 20inch ones can bend easily (think yours are 19)
- water pump - well documented failures. Common. See when yours was done. Plastic coolant pipe behind it can fail too
- would definitely have someone experienced check it all over thoroughly - they can be expensive to repair...
- 2009 and earlier 2010 has differential issues. Really expensive.. search on here for the vin range. And have it thoroughly checked
- sunroofs can rattle and work loose - will be obvious from the noise...
I'm sure there are others but this is a good place to start. Don't let it scare you - in general I've found it very reliable
Good luck!
Old Nov 15, 2016 | 08:02 PM
timfountain's Avatar
Good luck!
Regarding the diff issue. There have been a small number of owners who have reported issues. You post makes it sound like every car in the VIN range has or is going to fail. Many of the potentially affected cars have had a diff oil change. By now, if you have not had problems, the consensus is you are unlikely to....
Old Nov 16, 2016 | 04:11 PM
nasa25's Avatar
From what I understand most of the 09s were upgraded under warranty to the new diff setup. There's 41865 XFs out there that came stock with the old diff setup and I'm lucky enough to have one that was never converted over. Working with Jag NA right now to see what they can do for me. After 142k km I'm starting to get diff whine as well as bearing play in one of the axle shafts.
If the diff has ever leaked/had seals replaced, its an indicator that it would have a higher chance of failing in the future IMO.
Old Nov 16, 2016 | 06:10 PM
BritCars's Avatar
I can't talk to numbers on whether it's a few or a lot. But certainly no shortage of posts on here of people having diff issues on the car. And several recently with diff issues just starting. Hard to know if most have had fluid changed or not as I don't think it's a routine maintenance change.
So not sure about the consensus view. But if it were me buying used like the OP is, he may not know if it's a problem car that someone is trying to offload. So I would be very careful to have it checked out thoroughly.
