message center annoyance
Old Dec 3, 2014 | 07:00 AM
jaguar419c's Avatar
Default message center annoyance
In the message center it displays "check tire inflation". It will flicker off but comes back on and stays on for hours at a time. All tires are at 32-35 psi.
Old Dec 3, 2014 | 03:59 PM
hlgeorge's Avatar
Make sure the tires are the exact same pressure. When the temp changes we usually get an error. Give it time to reset. Also could be an issure with a TPMS, but try the same pressure first.
Old Dec 4, 2014 | 10:40 PM
jagular's Avatar
Try reducing the pressure to 30 psi then increasing it to the specified pressure. All tires must be at the same pressure for this TPMS to work properly 32-35 is not good. All should be at 32 or 35 whichever is correct.
What is the difference in temperature between the temperature when you check the pressure and the temperature where you are driving?
If the temperature is 55F in your garage but 32F outside then your tpms is going to display low pressure because the pressure is low. Tire pressure changes 1 psi for every 10 degrees F so 55F in your garage when you check the pressure is going to be 2 psi higher than at 32 F outside.
Old Dec 5, 2014 | 07:00 AM
jaguar419c's Avatar
Thanks to both of you.
X308XJR
May 20, 2019 06:50 PM
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
Stilling
Oct 5, 2015 04:23 PM
42Ajd
Sep 26, 2015 07:04 PM
