Need help! 2009 XF Coolant pump missing power wire. Was disconnected when I bought it
Old Mar 24, 2021 | 08:03 PM
Goodmantulsa's Avatar
Default Need help! 2009 XF Coolant pump missing power wire. Was disconnected when I bought it
Just bought this 2009 Jaguar XF supercharged and threw a po2601 code and I look under and the pumps not even connected. I searched for 2 hours and can’t find what to connect too. What is it supposed to be wired to? A relay? I searched all around the pump and nothing
Old Apr 5, 2021 | 05:41 PM
POD XF's Avatar
The harness for that plug should be located in the foam strip that seals between the side of the radiator and the panel; the bottom end of the foam strip is visible in the bottom left of your photo. From memory, the connector from the vehicle harness protrudes forward through that foam strip, the harness from the pump goes pretty much directly toward the rear of the car from the top of the pump. It would be hidden behind the pump in your photo. Let me know if you can't locate it there and if I get a chance with the bottom tray off I'll see where it goes from there so you can find the harness. Are you getting a 'restricted performance' message? Your intercoolers are just dead weight without that pump running.
Old Apr 6, 2021 | 02:19 AM
Originally Posted by Goodmantulsa
Just bought this 2009 Jaguar XF supercharged and threw a po2601 code .....
Welcome to the forums Goodmantulsa,
I've moved your question from General Tech Help to X250 forum. This is the place to post technical questions about your model.
Old Apr 29, 2021 | 04:36 PM
Bill400's Avatar
It may help to visit Gus at JagRepair.com - Jaguar Repair Information Resource.
He has kindly posted the electrical info that you need.
Don't forget to send a Paypal donation to help defray cost of the website.
They ain't free.
Old Apr 30, 2021 | 05:48 AM
fivel's Avatar
I'm not sure which engine you have, but on my 4.2 SC its as POD says, the wire goes towards the rear of the car from the top of the pump. Its a pig to get to, you can barely even see where it goes, I accessed from underneath behind the wheel on the right hand side between all the sub frame bits. It looks like this:
rjesq
Aug 26, 2020 01:53 PM
deepee002
Jul 11, 2018 03:45 PM
aconley
Apr 10, 2017 12:40 PM
