Oil check on 09 xfsc
Old Aug 14, 2019 | 05:28 PM
Fancy_beast's Avatar
Default Oil check on 09 xfsc
I noticed the 09 xfsc still has a dipstick (lucky me) but I have been reading and researching the car and a lot of xf owners say it needs to be checked while running? Not cold? But is that for people who have the dipstick or the digital gauge version? Thx guys, getting ready to change mine so just wondering. 👍
Old Aug 14, 2019 | 06:01 PM
OzXFR's Avatar
Checked while running is wrong, maybe you have misunderstood, you should never check the oil with a running engine and it can't be done anyway on those Jags with a digital oil level readout.
For all Jags with the digital oil level readout the Owner's Handbook says to run the engine for at least 10 minutes then shut it down then check the oil level.
The idea is to give it 10 minutes for the warm oil to settle back down in the sump so you get an accurate reading.
If it's been less than 10 minutes since you last shut the engine down the digital gauge method won't work, it will simply say "not available check handbook".
But if it's been a while since you started the engine, for example left overnight in your garage, the reading will work straight away as long as you just turn the ignition on and do not start the engine.
Old Aug 14, 2019 | 07:22 PM
Ok cool so then it's a normal cold check on the dipstick then for me? I'd enjoy it being normal, but I know jags have a few unique things lol so wanted to cover bases. You're the man ����
Old Aug 14, 2019 | 07:37 PM
OzXFR's Avatar
Whoops, I mucked up on one thing.
I said "For all Jags with the digital oil level readout the Owner's Handbook says to run the engine for at least 10 minutes then shut it down then check the oil level."
Bzzzz, wrong!
Run the engine until warm, then shut it down and wait for 10 minutes, then check the oil level!
Old Aug 14, 2019 | 10:50 PM
litteredwithfaults's Avatar
The 08-09 4.2 has the regular dip stick, which is yet another plus for this engine. It is checked cold the same as any non-fancy motor going back a century.
Checking while warm might be what OP read about dry sump engines, but the XF is a regular wet sump. More details in the owners manual for regular maintenance tasks.
woodturner
May 5, 2025 03:21 PM
DPK
Apr 20, 2024 08:37 AM
swajames
May 13, 2014 11:16 AM
Estilian
Sep 24, 2012 07:36 AM
jrwb
XJ40 ( XJ81 )
23
Jul 16, 2012 05:30 AM
