P062d problem
Old May 21, 2018 | 05:21 AM
auras's Avatar
Default P062d problem
I AM THESE CODES OF ERROR-error codes :-
E8 P0A94 DC/DC converter performance
P062D Fuel Injector Driver Circuit Performance (bank 1)
P062E Fuel Injector Driver Circuit Performance (bank 2)
CAN SOMEONE HELP ME?
Old May 21, 2018 | 05:55 AM
Welcome to the forum auras,
The Workshop manual gives the following 3 possible causes for P062D01:
1. Bank 1 injector(s) disconnected
2. Injector failure
3. Bank 1 injector circuit(s) - high resistance, short to ground, short to power, open circuit
The recommended actions are:
Carry out any pinpoint tests associated with this DTC using the manufacturer approved diagnostic system. Check injector connections to Bank 1 cylinders. Disconnect injectors and check resistance (200kOhm±20) of each injector, if out of specification install new injector(s). Refer to the electrical circuit diagrams and check Bank 1 injector circuits for high resistance, short to ground, power, open circuit.
Clear DTC and re-test. If DTC remains, disconnect ECM connector, and with injector(s) connected check resistance across injector pins, this should be no higher than the injector resistance.
Code P062E01 is the same possible causes and action for Bank 2.
Old Aug 9, 2022 | 02:59 AM
ionut's Avatar
Default salut
am si eu eroarea asta vroiam sa stiu unde ai rezolvat
stau cu masina in servis de o luna nu stiu ce sa ii faca
Old Aug 9, 2022 | 03:02 AM
ionut's Avatar
salut *** ai rezolvat eroarea p0a94 dc\dc coverter performance
Old Aug 9, 2022 | 05:11 AM
I have this error too, I wanted to know how you solved it. I've had the car in the garage for a month, I don't know what to do with it
Hello, how did you solve the error P0A94 DC/DC coverter performance?
Welcome to the forums ionut,
We are an International forum where the language used is English.
(Suntem un forum internațional în care limba folosită este engleza)
I find Google Translator very useful.
Dustin Moorman
Jan 10, 2023 08:42 PM
Guilherme Ribeiro
Apr 22, 2022 05:04 PM
EsRay
Aug 16, 2019 09:22 AM
Bcrary3
Sep 11, 2015 10:36 AM
Jagman1984
Mar 30, 2012 06:02 PM
