Parking Sensor/Front Bumper - '13 XFR
Old Sep 24, 2013 | 09:10 AM
fcastora's Avatar
Default Parking Sensor/Front Bumper - '13 XFR
So, after getting rear-ended in week 2, I've had a piece of road debris strike one of my front parking sensors and push it into the bumper. I can feel it inside the bumper. It's still working because it beeps horribly when I put the car in reverse and have to manually shut off the sensor.
I spent a few hours over the weekend removing a few dozen bolts attmpting to remove the under-side plastic plate but gave-up and replaced them all.
Has anyone attempted to repair one of these or gotten behind their front bumper? Is this a DIY project or am I in for a bill at Jaguar?
Thanks!
2013 XFR Speedpack white on black
"no tickets yet, but I'm trying"
Old Sep 24, 2013 | 09:33 AM
carzaddict's Avatar
so im assuming the sensor got pushed out of the hole and is hanging somewhere inside the bumper? Instead of taking apart the bumper, maybe you can fish it out with a wire hook and some tape.
if not, im sure you can find a diagram somewhere online that will show you install/uninstall of the bumper. I unfortunately dont have it, but im sure someone here does and will post it
Old Sep 24, 2013 | 12:13 PM
BritCars's Avatar
How frustrating - I feel for you!
Others have removed the front bumper and suggest it only takes 15 minutes or so to do it - see the posts towards the bottom of this link. That might give you some hope that you can do it yourself. Good luck!
https://www.jaguarforums.com/forum/x...lights-103018/
Old Sep 25, 2013 | 08:09 AM
ajmarton's Avatar
My suggestion is to go to a ding/dent removal shop that fixes cars before they are returned off a lease. Those guys are resourceful and cheap. They spot painted my front bumper from a scrape for $100. They also touch up rims. Most mobile services have a shop you can go to. Good luck. Andrew
Old Sep 25, 2013 | 12:51 PM
Redjaguar100's Avatar
With my pervious XF supercharged, I had access to the front sensors when I removed the headlight assemble. There are 3 screws holding the head light in place. From this position, it was snap to toch the front sensors.
danke
Sep 24, 2015 02:41 PM
Sublyminal
Sep 15, 2015 06:32 PM
Marque
Sep 14, 2015 11:17 AM
adam699
Sep 12, 2015 05:32 PM
