Hi all
Had my xf 3.0d for about a week and am very happy with it but one thing is bugging me.as far as I can see in the manual if you press the start button once with your foot on the brake it should switch the ignition on and then start the car.
But with mine I have to hold the button down to start it is this ok or is there something not right with it.
Many thanks in advance.
OzXFR
close
- Join DateFeb 2014
- LocationAdelaide, South Australia
Liked:3,658 Times in 2,688 Posts
Pressing the start button with your foot not on the brake pedal turns the ignition on but does not start the car. Pressing the start button with your foot firmly on the brake pedal starts the car. But you need to press and hold it for a second or so, not just press then let go. Sounds like yours is working as it should.
Yes, it's normal like that. Especially with a cold engine a long press is needed. In extreme cold even that may not start the crank but a second long press is needed. With a warm engine usually just a short touch on the button will start the engine.
Jouko
Jouko
