propshaft
Old Nov 24, 2021 | 02:36 PM
mcbutty's Avatar
Default propshaft
does anyone know what the universal joint part number is, is it replaceable ?, or do you have to buy the whole prop shaft, 2010 XF 4.2
Old Nov 26, 2021 | 07:19 PM
xalty's Avatar
you’d have to take it out and find the size
center bearing is much more common failure and easy to get
Old Feb 12, 2023 | 05:13 PM
Cragybar's Avatar
Sorry to hijack this thread , could you tell me where to get this centre bearing as I'm being told by everyone that it is not available, it's a full shaft only. From the measurements I can find it appears to be the same one as it fitted to the e60 bmw 530d but I am awaiting one of those coming into the local parts store (completely out of stock in Ireland) so it may take a week or more to get the part.
Old Feb 12, 2023 | 05:41 PM
xalty's Avatar
year please
early cars are skf for the lincoln ls the ones with the gkn diff i have zero clue
Old Feb 22, 2023 | 10:54 AM
Reaxions's Avatar
There's a thread on here which should tell you plenty: https://www.jaguarforums.com/forum/x...ispreloading=1
I'm using the SGF GAC02-004 and it works well.
Old Feb 22, 2023 | 01:19 PM
Cragybar's Avatar
Thanks for the reply but is that not for the doughnut rubber, not the carrier bearing. Lots of people talk about it but I cannot for the life of me find a part number for that. After reading those threads I've actually got the doughnut on its way now though so thanks but I still need a carrier bearing part number.
Bigg Will
Jun 2, 2022 07:37 AM
CzechFrank
XF (X260)
Sep 1, 2017 04:17 PM
eavr4
May 23, 2015 02:56 AM
hackman
Dec 3, 2011 09:23 PM
Wildcat_1
Apr 19, 2010 04:36 PM
