Good morning all. I have 2 questions about admittedly minor issues with my 2012 XF. First, I regularly listen to Sirius radio (ok to chuckle now). Is there any way to use the steering wheel controls to scroll through all available stations and not just the 6 presets on Sirius 1, 2 or 3? Could set it up that way on my e350 but no matter how I configure the touch screen the steering wheel controls only 6 presets. Second item...can the dash display be configured to show both the odometer and the fuel range at the same time? I usually leave the range setting on but then have to use the stalk to select a trip display that shows the odometer. Anyone with nothing better to do is encouraged to weigh in...except about why I listen to Sirius/XM. LOL.
I had the same question about the radio a while back but never had a response. I've looked through all the screens as well and I don't think you can do this, which is pretty lame. It defeats some of the purpose of steering wheel mounted controls, especially when you have to use the screen to change SAT1-3. I also don't think you can see the odometer and range at the same time, seems to just be one.
