seat belt chime
Old Apr 25, 2008 | 02:02 PM
FactoryJaguarTech's Avatar
Default RE: seat belt chime
Ummm buckle up? j/k
Sit in the vehicles drivers seat with passenger seat empty. Doors closed. Turn ignition to on (press start/stop button without foot on brake). While seatbelt light is illuminated, buckle the belt, once the light goes out, unbuckle, wait for light to come on, buckle up again. repeat this 8 or 9 times and you will get a confirmation tone.
This method is untested as such on the XF so let me know if that works.
To enable would be repeating the above procedure. It will not disable the light.
Old Apr 25, 2008 | 02:34 PM
KAZsam's Avatar
sounds like you'll get some kind of a workout also (a double benefit) lol
Old Apr 25, 2008 | 02:50 PM
Dennis's Avatar
ud
Buckle up..I don't want my tax dollars paying to hose your splatteredfaceoff the *** end of someone else's car you rear ended....You obviously have more money than sense..get achauffeur.
FJT..I wouldn't have told how to disable it...
Old Apr 25, 2008 | 03:03 PM
KAZsam's Avatar
Don't get youself all upset Dennis. In this day and age if you have to explain to someone other than a 5 year old as to why you shouldwear seatbelts it is not going to get through to them.[sm=sleeping.gif]
Old Apr 25, 2008 | 04:55 PM
The tellng was for the chime, not the light. If it makes you feel better, just picture a deaf person driving a car. They can see the light but the chime is irrelevant. I will not tell anyone how to disable that part.
Old Apr 25, 2008 | 06:29 PM
Dennis's Avatar
ud
Suppose you guys are right..Just pisses me off that some peole can be so lame..If they don't give a **** about themselves, that's one thing..but it's the other people that will be affected as a result of their selfish actions.
okay..rant off
Old Apr 25, 2008 | 07:04 PM
Roger that
Old May 1, 2008 | 11:00 AM
ken@britishparts.com's Avatar
Wow! Never thought I would hear a ligit reason not to wear a seatbelt. Now I have. And, Dennis, I back you 100%.
Old May 7, 2008 | 07:36 AM
KAZsam's Avatar
OK Thats fine in a police cruiser but if your talking about your own vehicle and you are off dutyNO (unless you are Dirty Harry)
Old May 16, 2008 | 10:49 AM
gvisgilio's Avatar
This method doesn't seem to work in the XF. After about four or five sequences of buckling with the chime and unbuckling when it stops, the chime stops period, so you don't get to the 8 or 9 iterations nor do you get a tone.
This does work in the S Type, but anyone know the secret to the XF?
GV
Old May 16, 2008 | 11:54 AM
Dennis's Avatar
ud
ORIGINAL: willie@edeniq.com
[sm=bounceybounce.gif]tHANK YOU FOR THE TIP,YES IT DID WORK. AND FOR EVERYONE ELSE THAT THOUGHT IT WAS A BAD IDEA, YES FOR YOU GUYS IT WOULD BE,AS FOR ME WITH OVER 20 PLUS YEARS AS A SO CALLED COP, AND THIS CAR WILL BE USED FOR U C WORK,I NEED TO GET OUT AT TIMES FAST,LOOK AROUND NEXT TIME AT OTHER OFFICERS,THEY SET ON THERE SEAT BELTS,AND THERE ARE TIMES WHEN YOUR GUN CAN GET CAUGHT OR CUFFS, THIS WHY IT IS SAFER FOR ME,THANKS FOR YOUR CONCERN, AND THANK YOU AGAIN FOR THE TIP....US MARSHALS[sm=innoc.gif]
Using an XF as an undercover car??...WTF..Don't they give you Crown Vics or something like that?
Old May 16, 2008 | 07:11 PM
jag_genius's Avatar
isnt that what you wanted..? no chime.. did it for a customer today.. worked on the 7th buckling.. no more chime
Old May 16, 2008 | 08:04 PM
gvisgilio's Avatar
Yes. But sorry my post was unclear. What I meant was that the chime stopped while doing the procedure so I wasn't able to get past four or five unbuckle/buckle sequences. But, the chime then resumed it's contant ringing afterwards when the car was started and driven if the belt wasn't fastened.
If you've done it on an XF and it worked, I'll try it again and see.
Old May 18, 2008 | 02:10 PM
gvisgilio's Avatar
Tried again; it worked fine/ Thanks.
Old Oct 31, 2019 | 11:50 PM
uclabrruin1989's Avatar
I just did this on my 2018 F Type. It worked. Ten year old thread, how about that?
I back in to my parking place at work and my garage at home and just feel restricted with the seat belt on while turning backwards. Hate those chimes. Thanks FactoryJaguarTech.
Old May 13, 2024 | 01:12 PM
styles's Avatar
I think this is suppose to be a technical forum. If your so morally affected maybe you should call Dr. Phil.
Thanks FJT
Old Aug 7, 2025 | 11:41 AM
DonManetti's Avatar
Originally Posted by FactoryJaguarTech
Ummm buckle up? j/k
does not work on Jaguar XF sportbrake 2013
closed the doors, only me in driver seat, pressed the start/stop button without starting the engine (no break pedal pressed), buckle/unbuckle 9+ times, nothing.....
Old Aug 8, 2025 | 03:12 AM
POD XF's Avatar
I'm going to try this- and I wear the seatbelt EVERY time I drive any car, I just don't need reminding of it and I hate all that nanny crap. When I get home, I look in my mailbox, get out and collect my mail, then have to listen to the stupid beeping whilst I drive the remaining 50 yards up my driveway.
