Short in fuse F40 (Intercooler pump) Possible causes?
Old Jan 13, 2017 | 01:23 PM
webshark's Avatar
Default Short in fuse F40 (Intercooler pump) Possible causes?
Hey guys happy new year!
Awhile back, my indie noticed a short in the fuse f40 which I believe is used for the intercooler pump. Every time tried inserting new fuse it blew, the guy at dealer made a guess that it could be intercooler leak and needs to be replaced, unfortunately extended warranty wont cover that.
Has anyone else had this issue? Does this sound like the most probably cause or what other things should be looked at?
And lastly how bad is it driving with this issue?
Old Jan 13, 2017 | 02:03 PM
10 XF Premium's Avatar
Does it blow right away without the car running (or powered on)?
If it blows after you start the car, then it most likely is a bad pump pulling way too much current. You can test this by unplugging the pump wiring and see if the fuse still blows.
They are fairly easy to replace and there is a good Bosch upgrade over the stock that you should consider. There are some really good threads on this process.
Good luck.
Old Jan 13, 2017 | 02:05 PM
Read here.
https://www.jaguarforums.com/forum/x...pgrade-152574/
Old Jan 13, 2017 | 08:29 PM
Bigg Will's Avatar
Well you should be getting a reduced power message once it warms up.
Old Jan 14, 2017 | 02:08 AM
webshark's Avatar
Good luck.
Yea as far as i recall it blows if the car is on or off. We tried 4 times different ways.
Old Jan 14, 2017 | 02:09 AM
webshark's Avatar
No messages as of yet, and ive driven her hard quite a lot.
