Small Coolant Hose that plugs into waterpump 2012 XF supercharged
I am about to replace my water pump. Would love to avoid breaking that plastic hose connector to the water pump. Is there a specific sequence to follow to disconnect the plastic hose connector from the water pump? Do I push in the retaining ring that sits in the water pump before pulling out the hose connector?
Thanks,
Mike
Thanks,
Mike
Nice find! I would be mildly concerned about galvanic corrosion with this part, same with the brass bleeder screw on top passenger side that a lot of people swap out from the factory plastic. I would overlook that concern if this is all that's wrong with the hose as we all know it's expensive.
https://www.ebay.com/itm/265027875966 The Brass connector from water pump.
or
https://www.rockauto.com/en/moreinfo...&pt=5516&jsn=1 The oil cooler outlet to the back of the Water pump?
You will need two sealing rings. It only comes with one.
or
or
or
David's XKR
08-12-2020 02:41 PM
marcela
05-19-2020 02:07 PM
