Tire question 285/35/20
Old Sep 15, 2023 | 10:35 AM
Sancho20's Avatar
Default Tire question 285/35/20
Anyone running 285/35/20 on the rear of a xf or xfr? I was looking for tires and I found a deal of 285/35/20s ..I believe they were only a half inch taller ,which would actually close the fender gap,but I just don't know if they will look dumb with the bigger sidewall..Thanks
Old Sep 15, 2023 | 07:21 PM
dennis black's Avatar
bent 3 of my rims never again ,back to19/40/245
Old Sep 15, 2023 | 07:39 PM
OzXFR's Avatar
They will fit perfectly OK on the rear of an XFR or any XF with the correct width rear wheels (9.5" or 10.0" I believe) and as you say they will also help to reduce the yuge fender gap. They will also improve the ride a tad and reduce the built in speedo over-read and bring it closer to accurate.
I say go for it!
Old Sep 19, 2023 | 12:26 PM
Sancho20's Avatar
I was kinda just looking for someone who may be running the same size to see if they look awkward and if they noticed a difference in ride quality..
Old Sep 22, 2023 | 09:22 AM
Ride quality does not suffer, and Looks good ,but in my case 3 rims bent so I went back to stock, got a little expensive
Old Sep 24, 2023 | 08:19 AM
Sancho20's Avatar
So you had 285/35/20 and went back to 285/30/20 which is stock ? I'm a little confused 285/35 is a taller tire so it seems less likely to bend a rim with a taller tire?
Old Sep 24, 2023 | 08:22 AM
Sancho20's Avatar
Anyways I went ahead and bought them ..couldn't pass it up they were normally $449 each tire ,got the pair for $224 shipped and everything came in 1 day also .Only issue is they don't make that model of tire in a 255/35/20 only a 255/40/20 ..So still deciding what to do for the front .
VicVegas84
Nov 18, 2019 11:32 AM
wimmer
Nov 3, 2019 08:58 PM
gochurush
Dec 13, 2018 07:08 PM
jonesy
Jun 22, 2014 07:24 AM
supercharged
Jan 2, 2011 12:35 PM
