Washed out backup camera image
Old Aug 22, 2013 | 01:26 AM
swaite3's Avatar
Default Washed out backup camera image
I have an 09 xf supercharged that I picked up about an month ago. The backup camera image seems very washed out, is this just the way they are or do I have an issue? Can you replace the camera with a higher resolution camera?
Old Aug 22, 2013 | 10:20 AM
rbobzilla's Avatar
Haven't had this problem on a Jag, but on a previous vehicle, the lens was situated in a way that it seemed to collect excess dirt and eventaully it got hazy. A little CLR solution took care of it right away, clearing the lens and sharpening up the picture.
Old Aug 26, 2013 | 09:15 AM
BritCars's Avatar
I've seen two causes of this on my XF. The first as rbobzilla says is that the lens can just get dirty. If you find it on the back of the car under the rear trunk lid, and clean the lens glass, you should find that fixes it. Mine gets very bad in the winter with the salty roads, so I've taken to wiping my finger over it from time to time and that keeps it clean enough.
Second cause may be that there is a brightness/contrast control that adjusts how bright the screen displays. I think it has an 'auto' mode that adjusts based on ambient light and also a day and night mode. I seem to remember you can access it from the menus. Possible that yours is on day mode permanently (and therefore looks too bright in dim light situations)? But I'd try cleaning the camera lens first.
Old Nov 2, 2013 | 06:34 PM
jaguarxfv8's Avatar
I had the same problem with the rear view camera on my 09 fx s/c premium luxury and I fix it for like 4$ it started like you said a whased out view then it went blue.
go check this LINK https://www.jaguarforums.com/forum/x...een-xf-105427/
IT might help you solve your problem
n8ertot
Oct 11, 2015 02:28 PM
Sonnyblack
Oct 4, 2015 05:42 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
millertic
Sep 30, 2015 08:11 PM
