Washer bottle level sensor
Old May 30, 2018 | 10:00 AM
Dustyblues's Avatar
Default Washer bottle level sensor
My 2010 XF is displaying “low washer fluid”.
It did this before and I changed the sensor but the warning has returned. It is intermittent and usually comes on after driving a few miles.
It is most annoying and I wonder if anyone else has experienced a similar problem?
And yes, the bottle is fully topped up
Old May 30, 2018 | 02:31 PM
lotusespritse's Avatar
Probably the sensor again. You can try shorting out the wires to the sensor to test it. And maybe leave the sensor off, and just fill up your washer fluid the old fashion way.
Old Jun 5, 2018 | 06:50 AM
Dustyblues's Avatar
Default XF Washer Bottle
Thank you for your response. Think I’ll disconnect the sensor connection and hopefully the warning light will disappear. Having checked both the original sensor and the replacement sensor with a continuity meter they would appear to be operating correctly so not sure why the warning comes on?
95 Cat
Oct 21, 2016 09:37 AM
JaguarVDP
Oct 6, 2016 11:52 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
warekito
Aug 9, 2007 10:02 AM
FL XJR
May 5, 2007 07:48 PM
