Wiring diagram needed for 09 XFs/c if possible.
Old Apr 23, 2018 | 10:54 PM
rjesq's Avatar
Default Wiring diagram needed for 09 XFs/c if possible.
Hey guys. I'm having issues with my Auxiliary Coolant Pump. Like many i've been experiencing the old RP mode linking to the pump in question showing circuit range performance. Installed new pump,bigger and better still had issues P2601circuit range performance. Checked fuse has lower power running to it. Does anyone by chance know which relay controls this pump. I have been told that its shared with the blower motor. Any guidance with this would be appreciated. CHeers
Old Apr 23, 2018 | 11:02 PM
OzXFR's Avatar
You can download a PDF of the 2012 XF wiring diagrams from my Dropbox here: https://www.dropbox.com/s/tacin632na...grams.pdf?dl=0
May not be identical to the 09 XF but most of it should be the same!
Old Apr 23, 2018 | 11:19 PM
rjesq's Avatar
Thanks OzXFR...
boultons911
Oct 26, 2024 09:37 PM
guanshee
Mar 19, 2018 11:53 AM
RayR
Feb 22, 2017 01:54 AM
danke
Mar 8, 2016 07:22 AM
