XF 2010 Workshop manual
Old Jun 13, 2017 | 02:40 PM
pnguy28's Avatar
Default XF 2010 Workshop manual
Does anyone have the XF 2010 Workshop manual? I am trying to troubleshoot an issue I have with my sunroof and wanted to see if someone can provide a workshop manual. If someone has a workshop manual, can you please share?
Thanks!
Old Jun 13, 2017 | 07:04 PM
OzXFR's Avatar
You can get the 2010-2011 XFR Workshop Manual (which also covers the 5.0 NA) from my Dropbox here: https://www.dropbox.com/s/bet26xniua...kshop.pdf?dl=0
In any event the sunroof on all 2010 XFs is the same regardless of model.
Old Jun 13, 2017 | 09:14 PM
pnguy28's Avatar
Thank you! Other than the workshop manual, is there any other manual for me to review when it comes to troubleshooting something or fixing/removing something from the car?
Old Nov 18, 2019 | 06:12 AM
Yangalla's Avatar
Default Your problem with your sun roof
Thanks!
I have the work manual
Old Nov 18, 2019 | 06:28 AM
Yangalla's Avatar
Sunroof Reset
If the battery is disconnected ,or the power supply is interrupted, whilst the sunroof is partially open it will need to be reset.
Once the power supply is restored ,reset the sunroof as follows:
!. Switch the Ignition on.
2. press the front of the sunroof switch ,so that the sunroof is in the tilt position , then release the switch.
3. press the front of the sunroof switch ,and hold for 30 seconds.
4. After 30 seconds the sunroof will begin to move. Keep the front of the switch pressed until the sunroof has fully opened ,then closed
5. Once the open/close cycle has completed and the sunroof has stopped moving release the switch
I hope this will help you
pnguy28 I hope this will help you
The sunroof can now be operated as normal
Old Nov 19, 2019 | 03:08 PM
Nyshadow's Avatar
I know this thread is old but could i use the 2010 Manual for my 2009? Is there a big difference between the 2009 and 2010 models?
Old Nov 20, 2019 | 06:16 PM
Swimref's Avatar
Except for the base model, all the 2010's had a different engine, the 5.0 liter direct injected V-8.
2013XF3.0
Apr 8, 2019 02:13 AM
wardo5757
Dec 12, 2017 09:31 AM
ugotmale
Apr 1, 2015 12:54 AM
