XF 2012 A/C problem
XF 2012 A/C problem
Hi all,
First of all, I read through all the threads which are on this forum regarding A/C problems, but the one I have is different?
Anyway, as the summer arrived and temperatures got higher my air con won't blow cold air anymore. I have re-gassed and checked for leaks, compressor works and turns on as you press the button on the dash, but still nothing.
The funny part in all of this is that it blows cold when it's around 20-22 degrees celcius outside, everything works and you get a cool cabin. Any temp over that it struggles and only blows warm. It's miserable!!
Has anyone had any similar issues? What should I check or do?
Jaguar XF 2012. 2.2d
