Headlight Flicker-2005 XJ8
Old Oct 19, 2014 | 04:56 PM
ronrowand's Avatar
Default Headlight Flicker-2005 XJ8
Occasionally at night driving, the headlights flicker off and on. No special conditions.
Old Oct 19, 2014 | 10:43 PM
etaent's Avatar
I just had a similar issue after changing my ballasts because of my drivers side light going completely out. the flickering light issue was a loose ground. The bolt that holds the ground wire was actually so corroded that it came right off when I wiggled the wiring to check it's integrity. Check that first if everything was working before.
Old Oct 20, 2014 | 06:01 AM
doc's Avatar
doc
I had similar issue tried the ground it turned out to be the headlight switch replaced the switch works fine both my headlights flickered
Old Oct 20, 2014 | 11:42 AM
Fraser Mitchell's Avatar
I, too, had flickering headlights and ignored it until one dark and moonless night two years ago they went out for about 2 seconds on a winding country road. So it just HAD TO BE FIXED after that !! A new lighting switch was fitted and all has been well since. Examination of the old switch showed it had been "fiddled with" so clearly the previous owner, (or the dealer that sold me the car), had tried to see what the problem was without actually getting around to fixing it !
Old Oct 25, 2014 | 01:31 PM
Sean W's Avatar
Mine was (and still is) the bulb. I haven't replaced it yet, but swapped the driver and passenger bulbs. Now the driver side is flickering, occasionally.
Old Oct 25, 2014 | 04:41 PM
I perhaps should have mentioned that in daylight, I used to get anomalous displays for the satnav, it would flick over to Night mode with the switch on Auto. This doesn't happen if it is just the headlamp bulb. In my case the lighting switch was causing the problem. It is a fairly common problem on the early cars. I think later switches were improved.
Old Oct 26, 2014 | 01:27 PM
ryejag's Avatar
I cleaned the aluminum contacts for my headlights and then applied silver conductive grease. I will report back to see how well this works to resolve headlight flicker.
some details attached, silver conductive grease, filed aluminum nut and aluminum stud and wires.
Hope this is helpful to all. I have used this same silver conductive grease on critical connectors on other vehicles. A little bit goes a long way.
RyeJag
Attached Thumbnails Headlight Flicker-2005 XJ8-20141026_125049.jpg   Headlight Flicker-2005 XJ8-20141026_125108.jpg   Headlight Flicker-2005 XJ8-20141026_125128.jpg
hoodun
Nov 20, 2022 02:35 PM
jagent
Jun 5, 2022 02:18 PM
bdboyle
Sep 16, 2019 05:58 PM
donald ebanks
Sep 30, 2015 07:08 PM
kevinl
Sep 24, 2015 08:25 PM
