XJ ( X351 ) 2009 - 2019
2015 XJL 5.0 Supercharged Smell under Acceleration
Old Jul 5, 2017 | 11:01 AM
socialjaguarfan's Avatar
Default 2015 XJL 5.0 Supercharged Smell under Acceleration
been noticing a strange smell from the vents every time I accelerate a bit more than normal and when going uphill. Is this normal for jaguar land rover vehicles? Any info on this issue? Thanks
Old Jul 5, 2017 | 11:13 AM
XJsss's Avatar
could it be the rear tires braking loose under the awesome acceleration of the 5.0 XJ
Old Jul 25, 2017 | 10:34 AM
clubairth1's Avatar
Community Influencer
Well just a guess?
But when you floor the gas pedal the A/C compressor is switched off to reduce that drag on the engine. So you should feel a bit of an effect with what's coming out of the vents.
Do you get any smell when starting the car? Pretty common to have some smells because of the moisture from the A/C.
