XJ ( X351 ) 2009 - 2019
2015 XJR additional radiator fan.
Old Jun 9, 2024 | 11:06 PM
AaronP220's Avatar
Default 2015 XJR additional radiator fan.
Hey guys,
Been talking with Robert at Mina Gallery. After installing pullies and a tune he recommends adding a high flow electric fan, 12” he said, to the front of the radiator / heat exchanger to help keeping the charge cooler.
Is this a job anyone has undertaken? If so, what fans did you get and where did you wire them in?
Here’s a little of running her down the road after being out of town for a few weeks.
https://youtu.be/FM_qxxZL5Zg?si=rNTAqxEalkCpkaJO
Cheers!
Aaron
Old Jun 10, 2024 | 10:44 AM
Vasara's Avatar
Just a thought: Would it be easyer to install 2nd radiator from 3.0L diesel version? (front of left front wheel) As far i have been understand the diesel are only version to have 2nd radiator?
Moutings are present and parts / open grilles well available as 2nd hand, since most selled verisons on EU side were Diesels.
Not sure how much more air can be pulled thru radiator even adding 5 fans to it...Every fan added create also airflow restriction.
hjanac
May 16, 2025 07:46 AM
adenshillito
Feb 8, 2016 04:52 AM
matts89xj
XJ40 ( XJ81 )
Sep 15, 2013 10:13 AM
BALTVISTA
Oct 1, 2009 05:33 PM
