XJ ( X351 ) 2009 - 2019
2016 3.0 xjl awd
Old Feb 18, 2024 | 04:03 PM
Tiggernlizzy's Avatar
Default 2016 3.0 xjl awd
Has anyone figured out a way to ungovern the engine and if so what is the actual top speed
Old Feb 18, 2024 | 06:27 PM
Thermo's Avatar
Veteran: Navy
If you look around, there are a few different tunes that you can get for your car. I am sure you can talk to them to get the info on the speed limiter and removing the limiter. With the fact that the car is making 340 hp, the car will most likely become drag limited around 170 mph You get the power up to around 400 hp, then you should be able to get near 200 mph.
Old Feb 18, 2024 | 06:42 PM
Default 22016 xjl 3.0
Thanks for the input, where would I look? I looked at super chips and they don't have anything
Old Feb 18, 2024 | 06:50 PM
Thanks I found some tuners!
Old Feb 18, 2024 | 06:51 PM
OzXFR's Avatar
Velocity AP (VAP) is the go around here for Jag tunes, see here: https://www.velocityap.com
Lots of happy customers including yours truly.
416 HP from a tune only, 450 HP from a larger crank pulley plus tune, 475 HP from dual pulleys plus tune.
I don't think VAP can remove the top speed limiter altogether (but maybe they can, just ask them) but they can bump the top speed up quite a lot from the factory limit.
Old Feb 22, 2024 | 01:43 PM
Thanks for the info !
Tiggernlizzy
Dec 10, 2023 05:06 PM
Clovis997
May 11, 2022 08:55 AM
stahlee
Jul 12, 2017 03:10 AM
maxmir88
Feb 27, 2017 03:14 PM
Lowkey
Apr 2, 2015 08:44 AM
