XJ ( X351 ) 2009 - 2019
2016 XJR oil
Old Jul 25, 2022 | 06:34 PM
2859bar's Avatar
Default 2016 XJR oil
It calls for 0w 20 oil and mechanic keeps telling me to use 5W-40 in it. He has been working on Jaguars and Land Rovers for the last 25 years and he says that this is what makes timing chain go bad. I had 2014 XJR timing chain go bad. i do drive it hard sometimes but should not go bad. he says use 5w-40 in it. any thoughts?
Old Jul 25, 2022 | 08:24 PM
wombat's Avatar
Yep,
He's WRONG!!!!
This engine requires a specific 0W-20 oil, and not just any 0W-20 oil.
There are many threads on this subject...just don't put 5W-40 in it, you'll wreck the engine.
wombat
Old Jul 25, 2022 | 08:34 PM
wombat's Avatar
Think of it this way.
My body requires about 11 pts of A+ blood (0W-20). If I replaced that with B- blood (5W-40), I'd likely die....just like your engine will.
wombat
Old Jul 25, 2022 | 11:53 PM
EliteZags's Avatar
I happen to know this particular mechanic, he also practices holistic medicine on the side and advises that drinking water is what leads to many degenerative diseases attributed to aging, and recommends drinking only hard liquor for prolonged lifespan
Old Jul 26, 2022 | 06:56 AM
wombat's Avatar
I'm starting to like him! I hope he thinks I should start smoking again, and stop going to the dentist?
wombat
Old Jul 27, 2022 | 05:41 PM
clubairth1's Avatar
Community Influencer
Were you using the wrong oil when you had the timing tensioner problems on your 2014 XJR? It's NOT the chain, it's the tensioner that's the problem.
I also race and have never found a faster XJ than mine. 174+ mph in the standing mile. Multiple times over multiple years.
I use what the factory recommends and I am at 53K miles. 0W-20 as per Jaguar. Do note that this has been changed from 5W-20 on your 2014. You can tell this as your oil cap will be marked 5W-20. Also you missed the biggest problem and that is the factory Jaguar change intervals are WAY too long! I change oil at 6K-8K miles.
At what mileage did you have your problems?
Old Jul 28, 2022 | 11:31 AM
2859bar's Avatar
always been using ow-20 oil. mine was bad. it was much worse than just timing. its over and have a new one now. not sure why another good guy that works on cars told me to use 5w-40. i am using only what JLR says to use
Old Jul 28, 2022 | 11:33 AM
2859bar's Avatar
Use castrol edge in gold bottle
Old Jul 28, 2022 | 12:40 PM
Freddy J's Avatar
At the end of 2021 there were four brands I know of that met the latest backward compatible Jaguar oil spec. What ever brand oil you use, make sure the spec on the bottle says it meets STJLR51.5122 (0w-20).
OzXFR
Apr 9, 2025 04:57 PM
bullet24
Sep 18, 2022 08:41 AM
a6kmita
Apr 20, 2017 04:42 PM
JaguaXJR
Aug 23, 2014 08:00 PM
barchettaboy
Oct 6, 2013 12:02 AM
