XJ ( X351 ) 2009 - 2019
Armor All wheel dust protectant.
Old May 9, 2014 | 02:39 AM
KingRT's Avatar
Default Armor All wheel dust protectant.
It does actually limit brake dust.
Before use, I could only drive one day and the rims where filthy.
I rate it a thumbs up product!
Old May 9, 2014 | 12:56 PM
LiquidIce's Avatar
Yep, I've been using it as well and like it...it does help a bit!
Old May 9, 2014 | 05:02 PM
johndahlheimer's Avatar
From: Mooresville, NC (Race City USA), home of most NASCAR teams.
I use it and it does help prevention and removal of brake dust, but I'm convinced that my '11 XJL will require ceramic brake pads and caliper covers to get the brake dust wheel dirting problem under reasonable control.
Old Sep 22, 2014 | 11:27 PM
LaCapitalRue's Avatar
I know I'm late to this post but I just started using Armor All wheel protectant last month. I was skeptical as I wouldn't normally use any Armor-All brand products on my vehicles but bought a few since they were on clearance for $3 a bottle. I must say I was pleasantly surprised to see that it actually worked. If catch them on clearance again, I will definitely load up.
Old Sep 23, 2014 | 05:54 AM
kratzerap's Avatar
I haven't tried it but I plan to but frequent cleaning with Mothers wheel cleaner does a great job and where we live in Florida we don't do a lot of stop and go driving anyway. I replaced the front pads at 118,000 miles and I just replaced the rear pads at 179,000 miles.
Old Sep 23, 2014 | 12:34 PM
amcdonal86's Avatar
Can you get it at the auto parts store or do you have to buy it online?
Old Sep 23, 2014 | 01:15 PM
Delta-V's Avatar
I'll have to try some. I don't do a lot of stop and go driving, but my rear wheels are always filthy. Only car I've ever had that the rear wheels got dirtier than the front. Not sure if it's the caliper not releasing properly or maybe the stability control trying to rein in my Hoonarian driving style...
Old Sep 25, 2014 | 09:56 PM
LiquidIce's Avatar
Hey mate, WalMart, Auto Zone, etc. all carry the product.
Old Oct 3, 2014 | 12:41 PM
irun123arkansas's Avatar
Just picked some up and will give it a try. The amount of brake dust off my XJL supercharged is crazy.
Old Nov 2, 2014 | 08:03 PM
Polyesterpig's Avatar
Actually on the XJ, the rear calipers activate first, then the front calipers second. Supposed to help reduce front end dive upon braking. Learned that from my salesman!
Old Nov 3, 2014 | 12:13 PM
amcdonal86's Avatar
That doesn't make sense...where do salespeople come up with this crap?
Old Nov 4, 2014 | 08:42 PM
Delta-V's Avatar
Hmmm...if you put more than 100% anti-lift in the rear suspension design, the rear brakes will pull the rear of the car down under braking. If you then put in a bunch of rear brake bias, the car will lower itself and brake level rather than the nose diving. The hard part is keeping the rear brakes from locking up, but the ABS system should be able to handle that.
Old Nov 5, 2014 | 07:28 AM
amcdonal86's Avatar
The issue I was questioning was the timing of the brake actuation, not the braking force.
Old Nov 5, 2014 | 04:59 PM
Delta-V's Avatar
Yes, but engineering-speak filtered through a salesman who likely wouldn't know a tie-rod from a trailing arm....may have come out as timing rather than force.
Old Nov 5, 2014 | 05:45 PM
amcdonal86's Avatar
Yep. And the people listening usually buy it!
BTW you have a beautiful X351!!!
Old Nov 6, 2014 | 02:03 PM
Update and correction. The front and rear breaks are activated at the SAME time, But MORE pressure is applied to the rear brake calipers to help reduce front end dive upon braking. This would explain why the rear calipers produce much more brake dust than the fronts. This is the only vehicle that I have owned where the rear wheels produce more brake dust than the front.
Old Nov 6, 2014 | 06:07 PM
amcdonal86's Avatar
That makes more sense. I was just busting your ***** anyway!
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
RobertTheBloke
Sep 24, 2015 11:48 AM
DustysSon
Sep 13, 2015 04:17 AM
lickahotskillet
Sep 11, 2015 07:54 PM
