XJ ( X351 ) 2009 - 2019
Battery Disconnected and Trunk Is Locked
Old Nov 9, 2016 | 01:33 AM
Sauce's Avatar
Default Battery Disconnected and Trunk Is Locked
I accidentally closed my trunk with my battery disconnected. I have a 2012 XJL is there anyway i can get in there without getting it towed to the dealer. U have already tried the jumper cable method and it doesn't work. Thanks
Old Nov 9, 2016 | 05:29 AM
Serlock's Avatar
So you pull a metal key from you key fob. Open door. Open hood. Jump start the car. Open trunk.
Old Nov 9, 2016 | 05:56 AM
jimbov8's Avatar
Or remove the rear number plate and put the key in that lock.
Old Nov 9, 2016 | 08:31 AM
XJsss's Avatar
Here is the procedure to open the trunk from your manual
File Type: pdf
Old Jan 19, 2017 | 07:41 PM
gagman66's Avatar
Thanks...it worked. I was pushing the trunk button on the car and not using the key fob.
Now, the get a new battery and get blade keys cut for the car.
