XJ ( X351 ) 2009 - 2019
Compressor air suspension Diagnose/Repair?
Old Jan 14, 2022 | 02:04 AM
theeogflip's Avatar
Question Compressor air suspension Diagnose/Repair?
Hi, i have a problem with my Compressor air suspension. I think they are malfunction :/
The compressor only makes a "click" when I connect 12V to the connection. And when I disconnect the 12V it makes a "click" again.
Anyone have any ideas on how I can check the compressor? I think he ran too long, maybe after the accident. But maybe i can open it and repair it. But i´m not sure how works the Compressor :/
Old Jan 14, 2022 | 06:38 AM
wombat's Avatar
When installed in the car, the compressor will only run when the car reaches a certain speed (20ish MPH from memory). The pump makes a lot of noise and the system is designed to use road noise to mask the compressor. The system only runs for a few seconds and only if the accumulator is low.
Your click may be the run command, or the power supply. You need both.
wombat
Old Jan 14, 2022 | 08:31 AM
theeogflip's Avatar
oh, thanks, i dont try this. So maybe i must not buy a new one
MickJagguar
Oct 4, 2016 04:26 PM
Ron T
Feb 10, 2016 04:34 PM
abonano
21
Dec 28, 2014 06:13 PM
amcdonal86
Jan 25, 2011 03:17 PM
oldmots
Dec 18, 2008 07:32 AM
