Cracking at the base of the window frame.
Anyone else notice the plastic trim cracking at the base of the window frame on the front doors? The black plastic trim wraps around the frame, and it looks like the window frame has enough flex to stress and crack the plastic. Doing it on both front doors, but worse on the passenger side.
Weird that you mention this, because just a few weeks ago I had one black plastic trim piece (vertical one, between the two doors) on the rear passenger side door crack at the top, and my dealer replaced it for me under warranty.
They initially thought that a stone or something must have hit it and caused the crack, but upon closer inspection they agreed that there wasn't any sign of any "impact" damage and it did appear to be a stress crack.
I agree with your assessment that the XJL body sure has quite a bit of flexing going on.
I have a diagonal stress crack on the lower lead edge corner of my driver side vertical black rear door plastic trim piece, perhaps 1/2" long. Bummer. If you hadn't mentioned it I might not have even noticed it.
Pictures would be hard to take because the cracks are hairline and have to be viewed under just the right lighting conditions. Plus, I don't know how to post pics.
99xk8guy
Sep 29, 2025 10:51 PM
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
Oct 24, 2015 05:49 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
