XJ ( X351 ) 2009 - 2019
Creaking from both front doors when driving (video)
Old Sep 7, 2023 | 08:40 AM
clubairth1's Avatar
Community Influencer
I just keep searching around and I don't always find it either. Most of these TSB's are listed by number on many sites but do not have the full text so there is some confusion if it's the TSB I am looking for. And as posted above they change them too!
I try to use JTB### but don't include any V's (Versions) as search terms. I hope to see all the versions so I can understand how things changed as Jaguar found out more on the problem.
Old May 12, 2024 | 01:56 PM
QP7's Avatar
QP7
So what happened on this? - did it fix the creaks. I now have creaks from both front doors, ugh ! It sounds like it is coming from close to the B pillar inside the doors near the top of the lower part of the door - i.e. just below the window..
Old May 13, 2024 | 04:34 AM
Lyktestolpe's Avatar
Both my dealer and me was sure that was the problems. But I never found anyone that had a tool small enough to fit. Tried for almost two months, but no one had or was willing to invest in the correct tool.
I ended up trading it in for an X351 long version without the creaking.
But it's a quite small job if the got the correct tool.
Old May 13, 2024 | 07:54 AM
clubairth1's Avatar
Be aware that your door seals are a source of creaks. With the doors moving slightly in the jams as the car goes down the road. I first clean the rubber weather stripping and then apply Sil-Glyde or Gummi Pflege. Some use spray silicon on them but I find that messy.
Gummi Pflege
Gummi Pflege Gummi Pflege
Sil-Glyde
Sil-Glyde Sil-Glyde
Try it before going deeper as it's surprising how much noise there is and I always figured it was because the XJ is so quiet you do hear all the little noises.
It does wear off and I have to apply at least yearly or when I get to noticing the creaks again.
Might save a dealer visit too?
Sancho20
Jun 28, 2023 10:38 AM
CRS 123
Apr 17, 2017 12:11 PM
Jeep2Jag
Sep 22, 2014 02:08 PM
Jaguarnewbie2011
Feb 5, 2011 09:41 AM
