XJ ( X351 ) 2009 - 2019
DSC is not available
Old May 31, 2020 | 03:42 PM
Braq33's Avatar
Default DSC is not available
Hello gents,
Recently ECM has been changed on Jaguare xj 2006 also EEPROM changed from old PCM
Car started but with limited performance when you drive it you feel like the car is not taking the order to accelerate dashboard shows "DSC is not available"
I connected SDD I found two permanent error.
U0300-55 internal control module software incomptability.
B1987 pedal forward/rearward motor stalled .
I tried to reprogram ECM but it gives me an error while reading climat control
I programmed REAR control module successfully
Would anybody mind helping me with this problem.
The car parked for 5 months just waiting for new box to arrive from USA.
I​ am waiting for some​ help as you know there is no shops specialized in jaguar in libya
Thanks in advance
Old May 31, 2020 | 06:12 PM
12jagmark's Avatar
That's the worst looking X351 (2010 - current) I've ever seen. Was it at the bottom of a lake?
Old May 31, 2020 | 06:58 PM
Braq33's Avatar
Default My friend
No but it barked for 5 months waiting for ECU to reach from USA and extra 6 month with this problem no one could fix it.
Old Jun 1, 2020 | 03:04 AM
Fraser Mitchell's Avatar
You've posted in the wrong forum, the car is an XJ6 built 2003-2009. You'll get far better responses if you move it to the forum for X350, X358. Found in the "Modern Jaguars" section.
Old Jun 1, 2020 | 10:34 AM
clubairth1's Avatar
Community Influencer
I did not see the SDD battery indicator?
You do have the proper power supply hooked up to the battery?
Good luck and yes you will get better answers in the correct forum.
Old Jun 1, 2020 | 10:47 AM
Braq33's Avatar
Default Fraser Mitchell
Thank you guys for replying, ok I posted the problem in the mentioned forum as you requested.
I hooked up charger and the indicator shows green.
Also I replaced the battery.
carzaddict
Photography
Nov 26, 2023 11:04 AM
sunchip
Aug 28, 2023 09:21 PM
Andrews
E type ( XK-E )
Sep 8, 2019 12:21 PM
