XJ ( X351 ) 2009 - 2019
Electrical issues and speed limiter
Old Aug 10, 2014 | 05:54 AM
dannyj12's Avatar
Default Electrical issues and speed limiter
I have a 2011 XJL. The RH mirror stopped working, but the puddle light and blind spot feature works, and it will move a little (and then stops again) once and a while when you hold the control in the up or down position. The door lock will not lock or unlock except manually (tried both keys and the driver side control will not open front or back windows,power lock won't lock or unlock the door) and the window will only work using the RH control, but no one touch (tried to reset that, but it didn't work). I'm going to take into the dealer tomorrow, but was hoping there might be an easy fix, like resetting something?
I was also wondering at want speed does the limiter come on. I know it's not safe to go that fast, but mine started to bog down at about 130.
thank for your help
99xk8guy
Sep 29, 2025 10:51 PM
Wolfy
May 28, 2024 08:06 AM
PMKimpton
Aug 3, 2019 08:22 PM
mcdutch
Sep 4, 2015 03:38 AM
OkieTim
Sep 2, 2015 12:48 PM
