XJ ( X351 ) 2009 - 2019
Fuel Pump Issue
Old Nov 30, 2025 | 12:10 PM
Friggins's Avatar
Default Fuel Pump Issue
Good day all. I have a new to me 2011 Jaguar XJL Supercharged that has a fuel pump problem. The code that came up was "fuel pump circuit open". I checked fuses, then dug into the fuel pump connector and found the ground with light burn marks. I tested the pump with a power probe, it seems to work! Then ohmed the ground out and got 800ohms? I am a licensed electrician but am new to car electrical issues. Is this enough to be a problem and make the pump not work properly? I have checked all the grounding connections I can find and they all seem good. I have the wiring diagram and grounding schematic. I would like to eliminate any other issues before I go ahead and start swapping parts. Any help will be greatly appreciated.
Old Nov 30, 2025 | 12:40 PM
NBCat's Avatar
What DTCs are stored in the system?
What is the fuel pressure with the engine running?
Old Nov 30, 2025 | 12:43 PM
NBCat's Avatar
Here is a link to the X351 Electrical Guide:
https://www.dropbox.com/scl/fi/1r3ho...=kmkskbi0&dl=0
Here is a link to the X351 Workshop Manual:
https://www.dropbox.com/scl/fi/uaje7...=krgllb2c&dl=0
Old Nov 30, 2025 | 01:50 PM
Friggins's Avatar
Thanks for the replies. I had to give up for the day due to rain. Unfortunately the car died in the driveway which is 1/4 mile away form the garage. I will let you know what the code and pressure is when it clears up!!
Old Dec 10, 2025 | 06:13 AM
Friggins's Avatar
Embarrasingly I found this issue. When I pulled the power probe off the ground, the terminal post connector came off with it, it was barely making a connection! Not only that but the battery was very weak. I replaced the battery, reconnected everything and the issue was fixed. At least now I am familiar with taking the rear seat out, wiring diagrams, grounding posts etc!!!! Now on to the next set of issues. .
Old Dec 10, 2025 | 01:51 PM
12jagmark's Avatar
Originally Posted by Friggins
Embarrasingly I found this issue.... .
That's great news - much better than it could have been!
SFRoBo
XK120 XK140 XK150
Apr 30, 2025 08:41 AM
Ziffo
Oct 24, 2024 10:14 AM
lofc2909
Jun 26, 2022 03:30 AM
Hog883
Sep 25, 2016 05:26 AM
Zolomoro
Jan 14, 2015 03:33 PM
