XJ ( X351 ) 2009 - 2019
Intake and Exhaust camshaft lobe to valve tappet clearance
Old Mar 20, 2026 | 11:39 PM
marlion's Avatar
Default Intake and Exhaust camshaft lobe to valve tappet clearance
Hello folks, I have an AJ133 motor and I want to know if my clearance measurements are out of spec, or is acceptable. All Data shows the clearance spec for the Intake cam to be 0.2mm with a range of 0.18 - 1.22 and the exhaust is 0.25 with a range of 0.23 - 0.27. Out of all 32 valves, I have 4 valves slightly out of spec.
Can someone tell me if 0.229mm for an Intake clearance and 0.279 for exhaust are out of spec for this motor? Replacement tappet takes me just below spec on both sides. Is it better to be slightly out of spec on the tight side or the lose side of the range?
littledan
Jul 24, 2021 11:05 AM
yachtmanbuttson
Apr 12, 2021 05:07 PM
FrickenJag
Mar 14, 2015 02:13 AM
Mr. Barry
E type ( XK-E )
Dec 7, 2014 11:53 AM
warrjon
Jun 26, 2012 02:39 AM
