XJ ( X351 ) 2009 - 2019
Jag XJ 2012 radio problem
Old Mar 9, 2024 | 12:35 PM
arbud's Avatar
Default Jag XJ 2012 radio problem
Hi all of you. Just got in to my Jag and the radio does not work. I am in florida heat, is it heat sensitive. Where might the fuse be for this. Thanks
Old Mar 9, 2024 | 06:04 PM
Thermo's Avatar
Veteran: Navy
arbud, you will need to check fuses F64, F68, and F69 in the central fuse box. Look at the buttons relating to the radio, are they lit and/or seem to have power? If so, then your problem most likely is Fuse F69 as that powers the monitor. F64 powers the radio itself. F68 powers the tuner which I would think you would still get some life from the radio if that was dead. The central fuse box is behind the rear seat center arm rest. If you put down the arm rest and then remove a flap of leather, you will see the fuse box there. If the fuses are good, then I would be looking at a new monitor for the car.
Old Mar 10, 2024 | 04:37 AM
Vasara's Avatar
Just simple check: Press the round volume button to see if its just turned Off.
JagLover1961
Audio/Visual Electronics
Jun 6, 2023 09:49 AM
Flex320
Aug 16, 2022 05:58 PM
Jeroen
Jun 26, 2021 03:49 AM
Tbilisi79
Nov 23, 2018 08:10 PM
XJL
Jan 20, 2015 12:34 PM
