XJ ( X351 ) 2009 - 2019
Lowering rear suspension
Old Oct 17, 2017 | 06:38 AM
Serlock's Avatar
Default Lowering rear suspension
The other day i raised front wheel with a jack and then lowered it back and i noticed how car lowered at the rear wheel. So i thought i wanna try to lower it permanently. I removed rear wheel, disconnected rubber thing from the suspension height sensor, put the wheel back, and then with a metal wire slightly adjusted that sensor hoping the car would lower itself. Nothing happened, except when i adjusted it a lot - dash started to show suspension fault. I put everything back nornally - no errors. all good. So i was thinking maybe i need to lower all sensors, the front ones as well to make it go lower. Because it really looks cool when lowered.
