XJ ( X351 ) 2009 - 2019
Mina performance parts - XJR
Old Aug 17, 2018 | 03:04 PM
Matt Cox's Avatar
Default Mina performance parts - XJR
2014 XJR
Would I need a tune if I just installed the intake tube, and exhaust package from Mina?
I know I would if I added their pulley swap, but didn't know if I could get by on stock tune with just the intake and exhaust only.
Also, any recommendations on a tuner in the Houston area that is reliable with Jaguar?
Thanks,
Matt
Old Aug 18, 2018 | 06:43 AM
Thermo's Avatar
Veteran: Navy
Matt ***, the answer is yes and no. I know this sounds confusing, but I will explain.
The engine computer is always learning what the air flows, timing, pretty much any parameter of the engine are. It then adapts what it does based on what it is seeing. So, as the engine wears and whatnot, the computer is adapting to the new conditions. So, when you add the new intake and exhaust, the computer is going to see a change and correct its accordingly. So, is a tune required. NO!!!!!
BUT!!!!!!!! (you knew it was coming). The engine computer can only adapt but so much and so fast. If you happen to reach the limit of what the engine computer can do, then you start loosing out on the maximums. In the case of the exhaust, the exhaust may be actually capable of netting you say 20 hp, but if the computer is limiting you, then you may only see a 10 hp change (with the other 10 hp being "lost" because of the computer). In this case, a tune would be needed to get the full effect.
So, must you get a tune. No. But, you may find that you will get more out of the improvements you are making if you do get the tune.
As for a tuner in the Houston area, cannot help you with that.
Old Aug 18, 2018 | 09:05 AM
XJsss's Avatar
Matt You may want to check the F-Type Forum as there are many threads regarding tunes. IMHO the two that seem to be good and haven't caused many issues are Velocity and ETG. Lastly you have Hennesey that is not to far from Houston @; 9281 SW Interstate 10 Frontage Rd
Sealy, TX 77474
jerome41441
US Southwest
Jan 9, 2016 08:03 PM
Robert Page
Mar 5, 2014 12:36 AM
vincent661983
Dec 19, 2012 04:57 PM
Viapa
Oct 26, 2009 02:22 PM
2004x-type
Aug 26, 2009 03:54 AM
