XJ ( X351 ) 2009 - 2019
part number for the lower air inlet chrome rings on the XJR front bumper
Old Nov 23, 2020 | 10:10 AM
carzaddict's Avatar
Default part number for the lower air inlet chrome rings on the XJR front bumper
not a fan of the little chrome horizontal pieces on the little air inlets in the XJ's front bumper...want to get more of an XJR look with the chrome rings instead, without buying an XJR bumper
1) would the rings fit?
2) what are the part numbers?
3) I will probably need to buy the mesh as well
Old Nov 23, 2020 | 10:18 AM
carzaddict's Avatar
update, i found the part numbers: https://parts.jaguarpalmbeach.com/a/...S/4726017.html
its #11 C2D41725 and C2D41728
the problem is, when i google the part number, it shows me BOTH the horizontal piece that i dont want, and the ring i do want. so im confused
Old Nov 23, 2020 | 02:00 PM
xdave's Avatar
As long as yours is a 2015MY then the base bumper cover is the same.
C2D41725 and C2D41728 are the blades which you already have.
You want these:
C2D41726, FW9M-17B970-BA, RH, chrome finish
C2D41729, FW9M-17C753-BA, LH, chrome finish
You may need the black mesh part as well, it is showing as a distinct part. IIRC the mesh for use with the horizontal blade is a unique moulding but I may be misremembering as I've only looked at them once.
C2D41720, FW9M-15K232-AA, RH, lower, open side mesh
C2D41722, FW9M-15K233-AA, LH, lower, open side mesh
To change them you need to remove the bumper cover from the car, turn it front-face down on a blanket and after removing the 2 screws on the rear of each you will need to use blades/screwdrivers to carefully release the captive tabs and then the rings slide out at a 45 degree angle (pull towards the centre of the bumper). Test each tab to find the one that binds first and then release that one and repeat. It is a pita job, but it will come out.
Old Nov 23, 2020 | 05:19 PM
NvmyJag's Avatar
I have done this on a 2012 XJL and it wasn't that bad at all.
Here is a thread where they did what you are wanting to do.
https://www.jaguarforums.com/forum/x...-135565/page2/
Old Nov 23, 2020 | 07:42 PM
carzaddict's Avatar
awesome! thanks!
FYI i dont think my car is 2015MY....would that be an issue?
Old Nov 24, 2020 | 01:36 PM
xdave's Avatar
The info I gave was for 2015MY and later only. You can tell if the car has the double J headlamps, or the earlier kind.
I can check the parts for the earlier cars if you need them.
Old Nov 25, 2020 | 08:33 AM
carzaddict's Avatar
i dont have the double J headlights
fried_hippies
Aug 17, 2020 04:42 AM
Mike K
Jun 11, 2018 03:40 PM
VPinGA
Mar 3, 2018 03:36 AM
dalecan
Jul 25, 2010 04:36 PM
sweet xk8
Dec 5, 2009 04:48 AM
