XJ ( X351 ) 2009 - 2019
Service required message
Old Jan 11, 2016 | 12:45 PM
JamesTX's Avatar
Default Service required message
When I start my car (33,000 miles), the message center briefly flashes "Service Required". The message goes away by itself, and when I go to the service menu, there are no warnings. Also, there are no amber lights on the dash.
I'd suspect it was telling me that the 30k service is needed, except there is no "service interval indicator" message.
Is this a normal part of the start cycle, or is there any way to see what the service required message is referring to?
Old Jan 11, 2016 | 04:31 PM
Thermo's Avatar
Veteran: Navy
James, a lot of our cars have this "message". Jaguar has put into the car a timer that has a 1 year interval. It is simply reminding you that you need to do the annual maintenance. Most just live with the message.
If you are truely "worried" about the message, if you look on a place like E-bay, they sell readers that you can plug it into the OBD port of your car and it will cause that message to go away for another year. They run about $100. This would be an example of one: New JLR Da Dongle Software V138 J2534 JLR SAE J2534 Pass thru Interface | eBay. Not sure if all of them do it, but I know this one does.
Old Jan 11, 2016 | 08:01 PM
retriever-007's Avatar
when was the last annual service performed on your automobile? Also, are you still under factory warranty since you did not indicate what year is your Jaguar?
theshortwhiteguy
Jan 10, 2016 05:29 PM
Roger Mabry
Dec 30, 2015 12:52 PM
Volbrewer
Dec 21, 2015 02:02 AM
Dam He Nice
Dec 19, 2015 01:54 PM
JessN16
Dec 13, 2015 02:34 AM
