XJ ( X351 ) 2009 - 2019
Side vent question
Old Nov 8, 2017 | 06:07 AM
dragonalfa's Avatar
Default Side vent question
the side vents which come with badges like ‘supercharged’ ‘r-Sport’ etc are the badges fixed with a plastic fitting or are they just stuck on to the side vent?
Old Nov 8, 2017 | 07:18 AM
Thermo's Avatar
Veteran: Navy
dragonalfa, there are 2 posts that go through the fender and there is a nut on the backside that holds the badge in place. 10mm?
Old Nov 8, 2017 | 07:53 AM
dragonalfa's Avatar
Ok thanks I’m guessing the ones which are selling as genuine vent badges on eBay are fakes then.
Old Nov 8, 2017 | 10:42 AM
Thermo's Avatar
Veteran: Navy
I am basing this off of what I recall seeing in the service manual. I have contemplated pulling mine off and mounting some amber lights behind the grill in the center and then using that as a side turn signal repeater. That is why it sticks in my head.
Old Nov 8, 2017 | 10:57 AM
XJsss's Avatar
I can confirm that the side vents are held on by two threaded posts with nuts and washers.
Old Nov 8, 2017 | 11:11 AM
dragonalfa's Avatar
Thanks for the replies
im guessing the actual vents pop off easy enough?
Old Nov 8, 2017 | 11:16 AM
XJsss's Avatar
You have to remove the inner wheel well liners on each side to get to the nuts.
