XJ ( X351 ) 2009 - 2019
Smaller Mud Flaps/Splash Guards
Old Aug 10, 2017 | 03:31 PM
gagman66's Avatar
Default Smaller Mud Flaps/Splash Guards
I ordered the below Mud Guards for my 2012 XJL SuperSport....
4 Car Mud Flaps Splash Guard Fender Mudguard for Jaguar XJ Sedan 2012-2016 | eBay
But received these:
4pcs Front Rear Mudguards Fit 2010-2015 Jaguar XJ Splash Guards Fender Mud Flaps | eBay
Question: Do the above smaller Mud Flaps exist, and how to order them? I have the Jaguar original ones, but don't particularly like the way they standout.
Old Aug 10, 2017 | 04:09 PM
Thermo's Avatar
Veteran: Navy
gagman66, I would first start with contacting the vendor that you purchased the desired mudflaps from and explain the error in the order and see if they are going to make the purchase correct. If they were purchased through a place like e-bay, I would first submit a question to the seller and see what their response is. If they come back and say that "you got what you got and we are not going to fix it", then you can file a complaint with e-bay and either get your money back or have them send you the correct mudflaps. Granted, you want to really get the vendor if they say that they are not going to fix the issue, write a review of the product and for the most part, down talk the mudflaps as the pictures are misleading/wrong/etc and that what you get is nothing like what the pictures show. Some vendors will respond by making the situation right as long as you remove your negative post. Others will simply delete the negative post. That is where you will have to have a copy of the negative post and keep checking back just to make sure the review remains on the site.
As the old adage goes, the squeaky wheel will get the grease.
Old Aug 11, 2017 | 08:06 AM
JagGate's Avatar
File a SNAD and try again maybe.
