XJ ( X351 ) 2009 - 2019
Spark plug change
Old Apr 27, 2020 | 10:22 PM
fossberry's Avatar
Default Spark plug change
Greetings fellow earthlings,
Seeing as my 2011 XJ 5.0 portfolio has done 100kms I'm going to replace the spark plugs (was thinking Bosch 96327 for these). Manual suggests using removal tool 303-1450. Failing that anyone recommend a alternative? What's the clearances like for getting a bog standard 14mm plug remover down there? Cheers in advance.
Old Apr 28, 2020 | 12:16 PM
XJ8JR's Avatar
Do a search for Big Will's spark plug change thread. His car is an XF but the same engine. No need for a special tool besides a more unique spark plug socket (I can't remember exactly what it is but it's listed in his thread).
Old Apr 28, 2020 | 05:18 PM
SinsterJag's Avatar
Just did mine, and the Lisle Long Flex Mag Pick Up Tool was my best friend. Here is the Part #:66580. Driver side is the worst side lol Good Luck!
Old Nov 13, 2022 | 05:21 AM
Steve Thornton's Avatar
hi I hope you are well I've got an xjr575 v8 am trying desperately to do the plugs got 3 done on bank a but the 4th I can't even get my hand to let alone any tools how did you do yours? And bank b looks just as impossible any help would be gratefully recieved many thanks steve
Old Nov 13, 2022 | 05:22 AM
Edit
Old Nov 13, 2022 | 07:54 AM
clubairth1's Avatar
Community Influencer
Did you follow the advice above?
Bigg Will made a nice thread on this?
I found this with a quick search?
5.0L Spark Plug Change
Old Nov 22, 2022 | 05:55 PM
for the most part its a case of let the dealer do it but ive got some wobble extensions and flexible bits coming along with hope a prayer a few choice words and a set of new fingers
fishbait1
Feb 8, 2020 12:54 AM
09XFSuper
Aug 23, 2018 10:29 AM
Madbrad
Jan 16, 2015 10:52 PM
redzed
Jan 30, 2010 12:20 PM
x-typeandbeyond
Aug 20, 2009 09:22 PM
